Add parts to cart if not on stock
11 years 2 months ago #120833
I want to have the possibilty to ad products to the shopping cart when they are not on stock. (So my clients can order parts not available)
I am unable to change this setting, are you able to help me with this?
11 years 2 months ago #120843
I don't think that this can be possible without some Hikashop code customization, but you can use the "waitlist" feature, then your customer will be able to ask you for an automatic notification when the product will be available.
You can enable the "waitlist" through "Hikashop->System->Configuration->'Features'->'Waitlist'".
Hope this will help you a little.
11 years 2 months ago #120853
Hello Mohamed,
Thank you for your solution.
Is it correct that the waitlist is only for the commercial version? Or did you mean the wishlist?
Greetings Kaz
  • Thank you received: 403
11 years 2 months ago #120886
Waitlist and wishlist are both available for all Hikashop version ;).
EDIT: thery are actually both available commercial version, my bad.
Last edit: 11 years 2 months ago by Eliot.
11 years 2 months ago #121017
No problem!
So there is no other way than purchasing it...?
Fo all your help I think I must! And will.
11 years 2 months ago #121023
Indeed, purchasing is probably the best solution :D.
Take a look at the compare page to see what you really need ;)
www.hikashop.com/extensions/compare-versions.html
11 years 4 weeks ago #130035
Hello Eliot,
I have purchased the commercial version a few weeks ago.
But the Waitlist solution is also not helping me in this moment.
I am able to deliver many parts, but i only have 500 different parts on stock (From a total of 35.000)
I have 2 questions.
1. What does it cost to customize my shop, so clients can order parts that are not on stock?
2. Can i change the notification settings so I get a notification when a part is added to a waitlist.
Greetings Kaz
11 years 3 weeks ago #130471
Purchasing out of stock products is on out TODO list. It's not yet available.
If you need this feature soon, you can ask for a quote via our contact form.
You can too post your resquest in the commercial jobs section of this forum.
To follow the waitlists, in a recent version of HikaShop we added the menu Customers > Waitlist which allow you to manage all the waitlists.
11 years 3 weeks ago #130485
Hello Xavier,
Thank you for your message.
I will wait for the update, is it possible to notify me when this option is available?
Is it possible to not show the quantity on stock?
11 years 3 weeks ago #130493
Hello Xavier,
I have just solved my problem.
I erased some text in the language option.
Now I can ad stock, without showing it to the customer.
So they can order parts, I not really have on stock.
  • Thank you received: 13378
11 years 3 weeks ago #130552
If you want to be notified of new releases, the best is to subscribe to our twitter feed:
twitter.com/hikashop
The following user(s) said Thank You: info@ifparts.com
