Weird calculation problems
12 years 10 months ago #131995
this is sad, that you take around a week or longer to answer. I am not used to this in support forums where I pay.
Regarding your second posting in this thread:
....If not, can you check that the file "invoice" of the view "order" was not edited via the menu Display>Views. If it was, can you save the modifications locally and click on the "remove customization" icon of the file so that you use the default view file of the latest version ?......
I was lost because I didnt find the Display-> Views.
I also sent you a screenshot where I looked after it. I also wrote: "....To be sure, I am in System-> Configuration-> Display
there also is no "remove customization" icon........"
You coudl well have cleared me up that I was at the wrong place.
Also, my mistake, but you could have told me that I am completely wrong there. :-(
I found now what you were talking about, where customizations should be done.
And locally I checked it out with the latest version.
Okay, I finally reached the old developer and I will be able to ask him what changes he made.
  • Thank you received: 4078
12 years 10 months ago #132145
Joomla World Conference
Part of our team is attending the Joomla World Conference, so you might experience some delay for our answers.
Thank you for bearing with us
Each time you answer to your own thread, you loose your place in the queue. So you will have to wait longer.
As you can read on in pages of this forum, we are currently in the Joomla World Conference so we have put an message in order to explain that you will have some delay...
I assigned your thread to Nicolas, he will answer you as soon as possible.
Thanks for your comprehension.
12 years 10 months ago #132173
yes, that will be good when Nicolas will answer, cause there might be some more questions too.
Sorry, never heard of a forum, where a push after 7 days of no answer increases the time I have to wait. I consider this a questionable answer of You.
12 years 9 months ago #134115
Hi, is the fair over and done?
So, we could step back into my case please.
Anything unclear what the problems are?
My main important question right now is, where would have the developer before me added the custom incoive, that is used ov er the buttons invoice on an order?
Andre
