How to add products in stock/warehouse?
10 years 3 months ago #165599
In order of processing a sales order, the product will have to leave our warehouse. But we need first to originate a vendor/supplier to add the product in stock.
Does anyone know - step by step - how to inload products in stock/warehouse?
  • Thank you received: 13377
10 years 3 months ago #165619
I'm not sure what is your question ?
If you want to set the stock of your products, you can do it in the field "quantity" of the product when you edit it.
If you want your vendors to do it for their products, you can setup HikaMarket Multivendor on your website so that they can do it directly from your website frontend.
