a box with different products
9 years 6 months ago #202738
-- Error-message(debug-mod must be tuned on) -- : i wanted to know if it is possible to fill a box with 6 different product
is it possible to have a box which is possible to fill with different products?
example: a box to fill with 6 different kind of beers.
I hope it is clear.
cheers
Massimo
  • Thank you received: 13376
9 years 6 months ago #202741
You could create a product with six options so that the customer could select between the beers for each slot of the box.
You can read more about options here:
www.hikashop.com/support/documentation/i...ct-form.html#options
