- Thank you received: 11
Point system not working on HK 2.5.0
- ler@singmuiheng.com
11 years 2 months ago #212832
by ler@singmuiheng.com
Point system not working on HK 2.5.0 was created by ler@singmuiheng.com
-- HikaShop version -- : 2.5.0_2015-08-30_00-54-51
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.4.35
-- Error-message(debug-mod must be tuned on) -- : No error message shown
Please help to verify if this is a bug
Point earned and existing point are shown during checkout process
Both HK and AUP are not getting points after order changed to confirmed
Database order table do not have serialize point parameter
11 years 2 months ago #212843
by Jerome
Replied by Jerome on topic Point system not working on HK 2.5.0
I'm sorry but I don't understand your explanation.
Can you please be more specific about the issue and your configuration ?
11 years 2 months ago #212871
Replied by ler@singmuiheng.com on topic Point system not working on HK 2.5.0
The problem is that the point are not genarated to both AUP and HK system
We install the latest version alphauserpoint released few days ago 2.0.2
We install your latest package and genarate the order_validation rule
We make new instance of plugin point rule for both hika point and aup point as screen shot below
We tested for all setting combination, price rate to point/ point /point for categories, but none of them work
Symptoms:
Points calculation correct at front end as screen shot 2
But in database, the point value are not store in order
O:8:"stdClass":1:{s:6:"prices";a:1:{s:3:"2@0";O:8:"stdClass":2:{s:14:"price_with_tax";s:7:"7.00000";s:3:"tax";d:0;}}}
Symptoms:
11 years 2 months ago #212927
by Jerome
That data is the data from the column "order_shipping_params" ; the points are stored in the column "order_payment_params".
Like :
We have to be sure that the data in the order is right stored ; then we will be able to investigate in the right direction.
Like :
O:8:"stdClass":2:{s:10:"userpoints";O:8:"stdClass":2:{s:10:"use_points";i:0;s:11:"earn_points";a:1:{s:2:"hk";d:11;}}}
11 years 2 months ago #212966
Hi Jerome
I checked the column order_payment_param but it is totally empty
I tried a backup copy of live site before update to 2.5 0831 on localhost and update to the latest version you provided, it is working fine
think smnthg is corrupted =="
11 years 2 months ago - 11 years 2 months ago #213002
by Jerome
What is/was your previous version ?
It looks weird because the plugin has just two modifications during May and nothing after.
The last modification for the plugin is the code to re-create the missing AUP rule.
The other is the replacement of the line
Into
In order to avoid a warning.. But we can use
instead.
if(isset($user->user_points) || in_array('user_points', array_keys(get_object_vars($user))))
if(isset($user->user_points) || ($user != null && in_array('user_points', array_keys(get_object_vars($user)))))
if(isset($user->user_points) || (!empty($user) && is_object($user) && in_array('user_points', array_keys(get_object_vars($user)))))
Last edit: 11 years 2 months ago by Jerome.
11 years 2 months ago #213014
I also find weird ....
However unable to replicate the problem now as I restore live site back to 2.4 backup amd upgrade to latest 2.5 directly. This method work fine
The earlier problem was by the step 2.4 upgrade to 2.5 without aup plugin, and then upgrade to the latest 2.5
Mayb other user will encounter the problem in near future
11 years 2 months ago #213017
by Jerome
Okay.
Let us know if the problem come again.
Okay.
