Insert products gift with a minimum cost
8 years 9 months ago #228950
-- url of the page with the problem -- : www.laputea.com
-- Joomla version -- : 3.1.0
I've read other posts on the subject, but I have not yet figured out how to do. I do not know if we have entered this function in the latest update hikashop.
I would like to implement the "product as a gift" feature if you spend at least 50. For example:
if you spend 50, product "x" as a gift;
if you spend 100 product "y" as a gift;
(Products are present in the store).
No matter if the products appear in the cart or must select the customer, the important thing is that they appear only when the customer reaches the minimum amount.
Can be done? If so, how?
Thank You! :)
  • Thank you received: 13375
8 years 9 months ago #228986
There is no such function. It would require the development of a small plugin to add/remove the product X or Y in the cart based on the current cart situation.
8 years 9 months ago #229016
I honestly do not know how to do. You can do it?
8 years 9 months ago #229029
If you need a developer to work on such plugin for you, you can contact our partners:
www.hikashop.com/home/our-partners.html
You can also post on the "commercial jobs" section of our forum.
The following user(s) said Thank You: gioxd
8 years 9 months ago #229282
I take advantage of your kindness.
I would like to enter the fidelity points, I know there is a plugin that manages them, but it should be integrated with component AlphaUserPoint, but it no longer exists! I do not find either the jed Joomla nor is there the site of the developer. There is an alternative way to activate the fidelity points?
Thanks so much!
8 years 9 months ago #229289
HikaShop user points system can be used either with AlphaUserPoints or directly with a custom user field. So you actually don't need AlphaUserPoints.
In fact, our documentation explains how to setup the points system without AUP:
www.hikashop.com/support/documentation/257-using-points.html
8 years 9 months ago #229441
Always efficient! Thank you!
