Charge a Fixed Cost for Setup Fee for my Products
8 years 3 months ago #246619
Pls i'd like to know how i can charge a Flat Cost to some category of my products(e.g. Mould Fee or Setup Fee)
For example, i customize items e.g. Wristbands, Lapel pins, etc. for my customers which requires that they Pay a constant Fixed cost no matter the quantity they're ordering that will be used in making the Mould excluding the standard cost per product. I want the Fee to be added to their total bill in the checkout page.
I created an 'item' custom text field named "Mould fee"(read only) and restricted it to my Wristband & Lapel Pin category. which displays the Fixed cost of the mould in the product page.
How can i make this fixed cost to be displayed & added to their total cost in the Checkout page?
or Is there a better way to add this feature other than this method? :unsure:
Expecting your reply. Thanks
Last edit: 8 years 3 months ago by Lordtech.
  • Thank you received: 13374
8 years 3 months ago #246670
You'll have to create instead a custom field of the table "product", not "item".
Then, you can use that plugin so that it sums the fee for each product (not based on the quantity) and add it as a global fee to the cart:
www.hikashop.com/forum/taxes/873285-fix-tax-import.html#190511
8 years 3 months ago #246673
Hi Nicholas,
I've installed the plugin but i discovered that it adds the fee on all the products in my store.
How can i make it restricted to just the customized products categories because i sell other digital services which doesn't require this fee?
Thanks once again
8 years 3 months ago #246680
In that case, you want to use this plugin instead:
File Attachment:
File Name: global_car...7-29.zip
File Size:2 KB
And in the value field, enter the column name of the custom field where you have the fee to charge for each product.
Last edit: 8 years 3 months ago by nicolas.
The following user(s) said Thank You: Lordtech
8 years 3 months ago #246792
Worked like charm.
Thanks a lot Nicholas
