Specific when is possible to order
  • Thank you received: 9
4 years 8 months ago #316627
-- HikaShop version -- : 4.2.3
-- Joomla version -- : 3.9.16
-- PHP version -- : 7.2.26
is it possible to specific the hours whene the customers can place an order (for example when a restaurant is open)?
Thank you for you support
Last edit: 4 years 3 months ago by pagemaster.
  • Thank you received: 13372
4 years 8 months ago #316635
Yes. You can do that with the shop closed hours plugin:
www.hikashop.com/home/blog/457-hikashop-4-2-3.html#hour
You can even restrict the hours differently for different categories with the improvements we've added to the system with the latest version of HikaShop.
You can configure that via the menu System>Plugins. You'll need to create new instances of that plugin, one per category (if necessary) per open hours range.
4 years 8 months ago #316696
Perfect. It works. Last question. Where it`s possible to edit the message that appears when is indicated that is not possible to buy something in specific hours.
Thank you very much
4 years 8 months ago #316699
You can use translation overrides for that:
4 years 8 months ago #316752
It worked
Thank you very much
4 years 3 months ago #322668
Now I have posted some topics in this forum. Is it possible to mark the topic solved as "Solved"? Also for help other people which topic is solved and which not
4 years 3 months ago #322671
what you can do is change the subject of the first post to add [solved] to it.
4 years 3 months ago #322756
I tried and the modify is marked as "Succesfully updated", but I don't see the modify. I have to wait some minutes. I have to wait that someone confirm the update?
Thank you for your support
Last edit: 4 years 3 months ago by Mohamed Thelji.
