Problems with order confirmation emails language
4 years 10 months ago #336959
-- HikaShop version -- : 4.4.4
-- Joomla version -- : 3.10.3
-- PHP version -- : 7.4.24
i have a website in italian and english where italian is the default language.
The link in the order confirmation mail sent to the users, points to the english version of the site even if the order was placed in Italian.
What am i missing?
Thank in advance
Last edit: 4 years 10 months ago by fullwater.
4 years 10 months ago #336961
I think it's a problem in the code.
In the file administrator/components/com_hikashop/classes/order.php we have this code:
$order->order_url = hikashop_contentLink('order&task=show&cid[]='.$order->order_id.$url, $order, false, false, false, true);
		$locale = $this->loadLocale($order);
The call to the loadLocale function is what properly sets the current language to the language of the customer. But it is placed after the line setting $order->order_url which contains the URL of the order.
So I think this code should be changed to swap both lines, like this:
It should then generate a link with the correct language.
The following user(s) said Thank You: fullwater
4 years 10 months ago #336981
Hi Nicolas, it works, thank You.
Are you planning to fix the code on next release or i'll have to change manually those lines on every single update?
4 years 10 months ago #336988
The modification is added on our end for the next version of HikaShop, so no worries.
4 years 10 months ago #337035
Nice of you. Thank you.
