Double click on add to cart button for products with variants in guest mode
3 years 2 months ago #339521
-- url of the page with the problem -- : www.aquanano.ro/index.php/produse/alte-m...coloidal-10ppm-500ml
-- Joomla version -- : 3.10.6
-- PHP version -- : 7.3.23
-- Error-message(debug-mod must be tuned on) -- : No error message
There is a difference in the behaviour of ADD TO CART button, when in GUEST or REGISTERED mode. The difference maniefests itself ONLY for products with VARIANTS.
If the user is in GUEST mode, one needs to press ADD TO CART button twice, for a product with multiple VARIANTS. If the product has only one VARIANT, all is ok, one need to press only once the ADD TO CART button.
Also, if the user is REGISTERED, one need to press only once the ADD TO CART button, regardless if the product has one or multiple VARIANTS.
Please check the product at the page mentioned, but note that we tested and the behaviour is the same, on all browsers.
For the moment, we let users know about issue in a banner, but it is so... unprofessional...Maybe you will sort out the problem.
Thank you,
Paul
3 years 2 months ago #339527
Unfortunately, we process some tests directly on your website and weren't able to reproduce your issue.
We precise that we have "login" as guest user, before processing our tests.
And solve your current issue will be difficult if we aren't able to experience it.
Then in order to progress on your subject can you provide these elements :
- A step by step process in order to reproduce the issue.
=> be as detailed as possible in order to provide even tiny elements that offer us some clues.
- Any settings elements that are specific, unusual or in your mind that can be linked to user settings.
Awaiting your returns to progress on your issue.
Last edit: 3 years 2 months ago by Philip.
3 years 1 month ago #339753
I made a movie with some tests, but it is rather long, being recorded with my phone, 334MB. I can send it ito you, but please let me know what is the method you would prefer for this.
Paul
Last edit: 3 years 1 month ago by NADEJDE.
  • Thank you received: 13533
3 years 1 month ago #339763
You could upload the file on wetransfer.com/ and then just provide the wetransfer link
3 years 1 month ago #340077
The movie can be downloaded from:
we.tl/t-rnwnRUb0Mv
I hope it can be downloaded and it is inteligible, as I did it with my phone camera.
Please let me know if you have problems with it.
3 years 1 month ago #340107
If I look at the HTTP requests on the page when I click the first time on the add to cart button, I can see this error:
i.imgur.com/Ug2JX51.png
Form submission has been blocked (TimeGate)
Looking for that error message on google it seems to bet something linked to the Joomla extension OSpam-a-not :
forum.joomla.org/viewtopic.php?t=937416
So check if you have it. If you do, try disabling that extension temporarily to see if it fixes the problem. And if it does, then you can check with the developer of OSpam-a-not what should be done. Maybe updating it if you have an old version ?
3 years 1 month ago #340109
Indeed, we are using Ospam_a_not.
We invalidated it and all seems to work well now.
What can I say: you arethe best!
We will try to submit the error to them, maybe they can make it work, as it is a useful plugin, however, for the moment, knowing the issue this is a very big relief.
Thank you.
Paul
3 years 1 month ago #340112
Always happy to have been useful and to read that your issue is resolve !
Don't forget that the best way to help us is to post a comment about our work in our Joomla Extensions Directory page !
Thank you for your kind feedback and we remain at your disposal!
Last edit: 3 years 1 month ago by Philip.
