no shopping cart icon on products with variants, no selection possible
3 years 4 weeks ago #340372
-- HikaShop version -- : 4.5.0
-- Joomla version -- : Joomla! 3.10.6 Stable
-- PHP version -- : 7.4.28
-- Error-message(debug-mod must be tuned on) -- : none - no shopping cart icon on products with variants
Since a short time we are experiencing the problem, that we can´t put products with variants in the shopping cart anymore. SHopping cart icon isn´t displayed and nothing happens on click on the Picture of that product. No popup, no display of the product itself, no chance to get into the description of any product.
need advise please...
best wishes
  • Thank you received: 13533
3 years 3 weeks ago #340390
Edit your menu item via the Joomla menu manager. There, under the "products options" tab, you have a setting "link to product detail".
You need to make sure this setting is activated, otherwise, it will remove the link on the image and product name on the listing.
3 years 3 weeks ago #340391
Also, I can see you have a bug with the "choose options" button not displaying well on the listing. We've actually fixed this yesterday.
Download again the install package of HikaShop 4.5.0 on our website and install it on your website to get the patch for this.
The following user(s) said Thank You: Machka
3 years 3 weeks ago #340392
I found the suggested option and now it works fine again.
ticket can be closed
