Manual adding of product issue
  • Thank you received: 5
2 years 9 months ago #342815
-- url of the page with the problem -- : weinpalais.de/
Since the last update, we cant add manual products by sku anymore.
The search field is empty. Pls take a look at my screenshots for better understanding.
Any idea?
Many thx
  • Thank you received: 13533
2 years 9 months ago #342826
It still works fine on our end.
Which version of Joomla are you on ?
What if you try with another browser ? Do you also have the issue ?
If you look at the console of your browser (F12) when doing this, do you get any errors ?
2 years 9 months ago #342920
Actually the issue was caused by Strato web host. The plugin System - DB Tweaks solved the problem.
At the end, it was no HikaShop bug.
Sorry.
Greetings...
