Move product description from bottom to right side
10 years 4 months ago #182625
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.3.13
I'm struglling to move Product description from "hikashop_product_bottom_part" to "hikashop_product_right_part" For the moment there will not be any other elements on the product page. they just want to have products as an product-gallery. But we agreed to use a web-shop solution so we can easily make it as a full web-shop later.
I have been throught this part: www.hikashop.com/support/support/documen...-display.html#layout
Under Display>Views "My template" Product show I belived I could easily move content around but no.. Is there a simple way to move around on elements?
I'm familar to html, css and some php.
  • Thank you received: 747
10 years 4 months ago #182628
Hi again,
You're on the right way, but probably editing the wrong view. Which one to edit depends on which product layout you have selected in the configuration. Probably it's set to "Default", means you'll need to edit the view "show_default" (not "show").
If that's the case, in "show_default" you'll find a div with id/class "hikashop_product_bottom_part", and inside the div with id/class "hikashop_product_description_main". This latter div you want to move to where you want it, in your case further up inside the div with id/class "hikashop_product_right_part".
The following user(s) said Thank You: janhelge, jimphillips
10 years 4 months ago #182633
Thanks again for quickly pointing me in right direction! Thanks lousyfool! :-)
