products out of stock are not showed ?
9 years 10 months ago #250904
-- url of the page with the problem -- : www.zebra-design.be
-- Joomla version -- : 3.6.2
-- PHP version -- : 7.0
-- Browser(s) name and version -- : google chrome 53.0.2785.116 m
Dear,
I would like that products out of stock are showed.
I have set:
  1. The Quantity of the product "Acapulco Ovaal Zwart" to 0
  2. Display out of stock products to Yes
but this product isn't visible ?
the page were this product is not showed is www.zebra-design.be/index.php/shop/category/44-stoelen
screenshots of the settings of the menu item of that page see attachment menu_item.png
What am I doing wrong please ?
PS: also attached an image of this product "Acapulco Ovaal Zwart.png"
TIA
Thierry
Last edit: 9 years 10 months ago by sindb.
9 years 10 months ago #250953
I see two points :
- Can you try to change your Item Menu Type for "Product listing" ?
I'm not sure that will solve your issue but you don't use an "External Url", so you don't have to select this Item Menu Type.
- Check in your Item Menu configuration, in your Products options tab, have a look on Product data display and on your Out of stock option.
Hope this will help you.
Last edit: 9 years 10 months ago by Philip.
The following user(s) said Thank You: sindb
9 years 10 months ago #250978
Thanks these sold out products are visible now :)
The only thing is that it doesn't show very well, please see attachment.
I want the text be larger + bold + in red.
Where can I change this CSS please ?
TIA
Thierry
9 years 10 months ago #250979
You can see this tutorial example, here to understand how customize your Frontend css.
9 years 10 months ago #251141
Dear Philip,
I use a Template of Templaza and their support put this CSS Front-end CSS File to NONE.
So i'm afraid if I follow that tutorial, I will have previous issues again.
What is your advice please ?
TIA
Thierry
  • Thank you received: 14184
9 years 10 months ago #251143
In that case, you need to modify the CSS of the template itself.
The method to learn where is the CSS you want to modify is basically the same but instead of editing the frontend CSS of HikaShop, you want to edit one of the CSS files of your template.
The best is to contact your template provider support to check with them what is the preferred approach they recommend for that.
Time to create page: 0.313 seconds
