Hello everybody,
here is a simple customized template to show the related products module before the reviews instead than at the bottom of the page, actually I have inserted a new module position in this template, so you can show any module between your product description and the reviews, just assign your module to this position
tip: in Joomla you just need to type the new position in the "position" field of your module to have it added to the system
to use this template you have to overwrite your "product / show.php" template in "display > views"
hope this helps!
File Attachment:
File Name:
show.zip
File Size:4 KB
