speed up my site (product images)
6 years 9 months ago #294288
-- Joomla version -- : 3.6.2
-- PHP version -- : 5.5.38
hi
im trying to speed up my site
can you tell me how i can reduce the quality of the images when im using category list or product list? i mean if the products being displayed are more than 1 and images are only thumbnails, i would like to reduce the quality.
if it is a product page not much compressions is needed.
thank you
  • Thank you received: 13533
6 years 9 months ago #294298
You can edit the file "listing_img_title" of the view "product" or "category" and change the line:
array('default' => true,'forcesize'=>$this->config->get('image_force_size',true),'scale'=>$this->config->get('image_scale_mode','inside'))
to something like that:
array('quality' => 50,'default' => true,'forcesize'=>$this->config->get('image_force_size',true),'scale'=>$this->config->get('image_scale_mode','inside'))
where 50 is the compression percentage.
