SOLVED! - Product Copy - error 167 Out of range value for column 'product_id'
  • Thank you received: 5
6 years 8 months ago #296178
-- url of the page with the problem -- : www.ovrsupply.com
-- Joomla version -- : 3.8.11
-- Error-message(debug-mod must be tuned on) -- : An error has occurred.
167 Out of range value for column 'product_id' at row 1
When selecting a product and clicking the "copy" button... I get "An error has occurred.
167 Out of range value for column 'product_id' at row 1"
Thanks for helping me solve this...
Last edit: 6 years 8 months ago by shockoe.
  • Thank you received: 13533
6 years 8 months ago #296181
This problem is probably the same as the one here:
www.hikashop.com/forum/product-category-...-in-product-tab.html
You must have done something to the hikashop_product table via your phpmyadmin which broke the way HikaShop can add new entries to that table.
If you're not aware of any change made to that table, please look at the structure of that table via your phpmyadmin. If you can provide a screenshot of that page and the indexes there, that would be great.
6 years 8 months ago #296220
I didn't change anything in any database tables? I've attached the screen shot you requested and also sent you (via contact form) cPanel access so you can take a look at the database.
Thanks in advance for the great help.
6 years 8 months ago #296235
