Hikashop not displaying products in collums
6 years 5 months ago #299902
-- url of the page with the problem -- : xmemories.co.za/buy-online/kalahari-rally-2018
-- HikaShop version -- : 4
-- Joomla version -- : latest
-- PHP version -- : 7
I have sellected hikashop to show my products in collums but it still, display each in one collum
Last edit: 6 years 5 months ago by PWessels.
6 years 5 months ago #299909
Your issue is coming from a CSS code customization from the file "media/com_hikashop/css/frontend_custom.css", editing or removing the following code will probably do the job :
.hikashop_subcategories div.hikashop_category, .hikashop_products_listing div.hikashop_product { float: left; width: 100%; } |/code] For more information about CSS code customization : https://www.hikashop.com/support/documentation/153-customize-the-display.html#css Kind regards, Mohamed Thelji.[code]
float: left;
width: 100%;
|/code]
www.hikashop.com/support/documentation/1...the-display.html#css
Kind regards,
Mohamed Thelji.
6 years 4 months ago #300245
I don't think this is because a user customized css code as i have the same issue.
The solution should not be the editing of a css file but should be done through hikashop menu.
Last edit: 6 years 4 months ago by perlamoldovei.
  • Thank you received: 13516
6 years 4 months ago #300249
We can't be sure that it comes from that on your website if you don't provide a link to the page with the issue (so please do that so that we can have a look).
However, in more than 90% of the cases where people contacted us about that "one column" issue, it came from that.
You can read more about it here:
www.hikashop.com/forum/install-update/88...mn-after-update.html
6 years 4 months ago #300289
Yes. I commented width: 100%; on that line and the problem was solved. This is why i say it may be something related to hikashop and not something that was modified by the site administrators.
