[SOLVED ]Related product carousel module not showing
  • Thank you received: 8
6 years 4 months ago #301024
-- url of the page with the problem -- : accademiainfinita.it/shop/prodotto/il-potere-della-visione
-- HikaShop version -- : 4.0.0
-- Joomla version -- : 3.9.0
-- PHP version -- : 7.2.12
-- Browser(s) name and version -- : Firefox 63.0.3
my related product carousel module doesn't show anymore in the product page
eg: accademiainfinita.it/shop/prodotto/il-potere-della-visione
the module is it rendered, I see it in the source code and I see also the module title "Ti consigliamo anche: "
but the carousel does not load
I can see these errors in Firefox Console:
registerEventsMessage called ial.js:3277:17
ReferenceError: jQuery is not defined[Ulteriori informazioni] jquery.ui.core.min.js:5:2
TypeError: a.ui is undefined[Ulteriori informazioni] jquery.ui.sortable.min.js:17:16
SyntaxError: missing { before function body il-potere-della-visione:1069
SyntaxError: missing { before function body il-potere-della-visione:1111
SyntaxError: missing { before function body il-potere-della-visione:1142:1
SyntaxError: missing { before function body il-potere-della-visione:1496:2
SyntaxError: missing { before function body il-potere-della-visione:1601
SyntaxError: missing { before function body il-potere-della-visione:2826
SyntaxError: missing { before function body il-potere-della-visione:2911
SyntaxError: missing { before function body il-potere-della-visione:2925
SyntaxError: missing { before function body il-potere-della-visione:2958
SyntaxError: missing { before function body il-potere-della-visione:2979
SyntaxError: missing { before function body il-potere-della-visione:3253
SyntaxError: missing { before function body il-potere-della-visione:3257:2
L’utilizzo di Mutation Events è deprecato. Al suo posto utilizzare MutationObserver. main.js:1:23375
ready: before call parse for last time
Object { timer: null, count: 0, error: true, data: null, parsedOnReady: false, readyEventTriggered: true, locationUrl: "" }
The module was showing normally some days ago, the only change I made recently was updating Joomla to the latest version but I can't recall if the issue started after that.
hikashop related products module settings here: nimb.ws/hs53KJ
the "product > show " view is customized with some minor changes, but even reverting to the original file doesn't solve the issue
the product is correctly associated with several others and as far as I see the related product module setting are fine
Thank you
Last edit: 6 years 4 months ago by oloccina.
6 years 4 months ago #301026
SOLVED: this conflict is caused by the latest version of "modules anywhere" plugin
loading
