Related products module not visible in checkout page
  • Thank you received: 8
6 years 2 months ago #302131
I am trying to show a related products module in the checkout page under the cart, but for some reason it doesn't show.
Is there a particular setting in hikashop that maybe I am missing?
module settings: nimb.ws/N1q8ir
to test: go here accademiainfinita.it/shop
put something in the cart and proceed to checkout
the module should be displaied in this page accademiainfinita.it/shop/cassa
I tried several template positions as well as assigning the module to all menu items instead than just the checkout page, it is still not displaied
Thank you
  • Thank you received: 4032
6 years 2 months ago #302137
You have the "recently viewed" setting activated ; so I'm afraid it could generate some unwanted side effect on what product could be displayed in the module.
I would recommend you to disable most of restrictive settings so you will have your module display where you want, and then, activate the "related" restriction to only show related products.
6 years 2 months ago #302162
Thanks Jerome,
the problem was also that I didn't select "all sub elements" when configuring the products category. Now is solved
