Problems when i add a product to the cart
6 years 1 month ago #303465
-- HikaShop version -- : HikaShop Business 4.0.2
-- Joomla version -- : 3.9.2
-- PHP version -- : 7.2.14
When i add a product in the cart, the layout of the cart is messed up.
i you press F5 the problem is solved?
How do i fix this problem.
  • Thank you received: 4032
6 years 1 month ago #303473
When we try to access to your website we got the message :
403: Access Forbidden
Your location (FR) has been blacklisted.
PS : If you posted you question via our "contact us" form ; please do not duplicate it in the support forum. Thank you for your understanding.
6 years 1 month ago #303505
Fr has access now.
6 years 1 month ago #303521
Thanks for your return, it able us to correct and improve the Cart Module Design plugin !
To have the correction you just have to upload again the plugin.
Last edit: 6 years 1 month ago by Philip.
6 years 1 month ago #303529
i tried it and it works.
Thanks for the support
