Supplier info and/or notes on Products backend
5 years 8 months ago #308095
-- HikaShop version -- : 4.1.0
-- Joomla version -- : 3.9.8
Hi, is there any "Supplier Module" or any "Free comments Module" for products only visible on the back-end?
The idea here is to be able to add specific information's and/or notes about particular item.
Last edit: 5 years 8 months ago by Pgva.
  • Thank you received: 13505
5 years 8 months ago #308109
I'm not sure what you mean.
If you want the merchant to be able to enter additional information to the products, you can create custom fields of the table "product" via the menu Display>Custom fields.
If you want users to be able to add information to the product page, you could activate the vote & comments settings under the "Features" tab of the HikaShop configuration.
5 years 8 months ago #308165
Got it thanks
