Products display position.
  • Thank you received: 8
5 years 8 months ago #308579
-- url of the page with the problem -- : www.luxminime.com/en/boys/boys-column-1/pants
-- HikaShop version -- : 4.1.0
-- Joomla version -- : 3.9.10
-- PHP version -- : 7.1.30
The products appear below the filters as opposed to at the side.
Hope you can help.
Colin.
  • Thank you received: 13505
5 years 8 months ago #308581
That's because you've activated the filters display setting of your menu item via the Joomla menu manager instead of turning it off and configuring the HikaShop filter module to be displayed on the sidebar position of your template via the Joomla modules manager.
Do that change and it should be ok.
5 years 8 months ago #308591
Thanks for your help with this.
I made the changes, but the filters do not show on this page now.
This is a duplicate site of the one here: ' banobathrooms-co-uk.stackstaging.com/sui...re/view/sinks-basins ' and the filters appear correctly with the filter module in the 'Search' position and the same menu settings?
Colin
5 years 8 months ago #308600
Well, I don't know the settings of your filter module nor the settings of your filters so I can't say much but it most come from them.
We would need screenshots of these to be able to help.
The following user(s) said Thank You: Crashbandi
5 years 8 months ago #308721
Hi, This was an issue with the template. It's resolved now.
Colin.
