Problems with pagination of subcategories e products in the same page
5 years 6 months ago #310350
-- HikaShop version -- : 4.2.1
-- Joomla version -- : 3.9.11
-- PHP version -- : 7.2.18
When displayed in the same page the subcategories with pagination and also products with pagination, the pagination of subcategories won't work. If you try change "page" of subcategories the pagination change the products instead of subcategories.
For examples, the link for page 2 of subcategories have the same URL of link for page 2 of products.
Can you help?
Best regards.
  • Thank you received: 13504
5 years 6 months ago #310366
Thank you for your feedback. We were able to reproduce the problem on our end and added a patch for it.
Download again the install package of HikaShop 4.2.1 on our website and install it on your website and you'll get the patch.
5 years 6 months ago #310369
I installed again the package and now works fine!
Thanks a lot.
Best regards,
Bruno
5 years 6 months ago #310379
I found another problem with the pagination: the select where you can choose the number of products shown (16, 32, ..., all) is not working. In the case of subcategories works correctly.
Can you help?
Thanks!
Best regards,
Bruno
5 years 6 months ago #310466
Thank you for your feedback. I was able to reproduce the issue and added another patch for that.
