Column Width problem
  • Thank you received: 6
5 years 5 months ago #311916
-- url of the page with the problem -- : formidogrijswijk.nl/vers
-- HikaShop version -- : 4.2.1 business
-- Joomla version -- : 3.9.12
Good morning
After updating the Hikashop component to 4.2.1 (business) I have a column problem on the category pages.
The left column, with the filters, breaks into the main area.
Where can I repair this?
Thanks in advance,
Dick
Last edit: 5 years 5 months ago by Formidog.
5 years 5 months ago #311918
Hi try this for the Column width:
Go into ure hikashop.css in Folder: media/com_hikashop/css/hikashop.css on line 1237 and set this
.hikashop_filter_fieldset {
    display: inline-block;
to this
    display: block;
after this go to ure custom.css of hikashop and write this:
#slider_Size_3_hikashop_category_information_menu_138 {
display:inline-block!important;
width:100%!important;
best regards from Germany ;-)
Last edit: 5 years 5 months ago by SchmidtSon.
  • Thank you received: 13503
5 years 5 months ago #311934
Please don't edit directly hikashop.css as it will be overwritten after each update of HikaShop.
If you want to change that CSS code, it's better to add such CSS to your custom CSS file:
    display: block !important;
5 years 5 months ago #311967
nicolas wrote: Hi,
Yes that´s true,
my mistake, sry i had the same Problem, after this i only write into the custom.css ...
Best regards
