Next & Previous buttons to navigate between products not showing
5 years 5 months ago #312171
-- HikaShop version -- : 4.2.1
-- Joomla version -- : 3.9.12
-- PHP version -- : 7.2.22
Hello Hika,
I want to navigate between products. I've set the option 'show link between category products' to yes in the configuration, but nothing is showing.
Did I miss something?
With kind regards,
Rachel Walraven
  • Thank you received: 13503
5 years 5 months ago #312173
The buttons will only appear if there are other products with the current product in the main category of the current product.
Also, CSS from the template could make the buttons hidden. We would need a link to a product page to check on that though.
5 years 5 months ago #312228
Thanks for the tip. It was a CSS issue.
With kind regards,
Rachel Walraven
