Display of products messed up
  • Thank you received: 4
5 years 5 months ago #312233
-- url of the page with the problem -- : www.brogaardensisheste.dk
-- HikaShop version -- : 4.2.1
-- Joomla version -- : 3.9.12
-- PHP version -- : 7.2
In this webshop some products listings is with empty spaces but when I refresh the page everything is as it should be the first place (see attached screen dumps).
Any idea what is wrong?
Best Regards, Anders
Last edit: 5 years 5 months ago by anders.drejer.
  • Thank you received: 13503
5 years 5 months ago #312235
I couldn't find the page with the issue so I couldn't look at the CSS/HTML to see why you have that some times and not some others (make sure that you give the URL to the exact page and not just the URL of the website when you create your thread).
However, I think you can fix that by forcing the height of the products.
For example, by adding such CSS:
.hikashop_product { height: 350px !important; }
5 years 5 months ago #312249
Sorry about this. Here is the url: www.brogaardensisheste.dk/dk/butik/categ...25-veste-og-tunikaer
The ccs code is added to the custom css file, but it does not seem to have any effect.
Best Regards,
Anders
5 years 4 months ago #312258
I'm not able to see the issue on that link. all the products are properly aligned there:
monosnap.com/file/e4Ht4TuDnTlriVTe6fy3STLiX52Z5u
Could you double check ?
Could you try with another browser / clear your browser's cache ?
5 years 4 months ago #312267
It is also working for me now, so maybe the css code did the trick after all.
Thank you
Best Regards Anders
