Display products alphabetically
5 years 1 month ago #315378
Hello, how to display products inside all categories alphabetically Title A-Z?
Now in some categories products are Title A-Z
www.brillbird.com.hr/shop/top-kategorije...a/33-akrilna-tehnika
and some are Title Z-A
www.brillbird.com.hr/shop/kategorija/59-gradivni-gelovi
Thank you
  • Thank you received: 13502
5 years 1 month ago #315380
Edit your menu items via the Joomla menu manager. In them, look at the "products options" tab and check the "ordering column" and "ordering direction" settings.
You should have the first one set to "product_name" and the second one to "ascending" if you want the products to be ordered in alphabetical order starting with A.
5 years 1 month ago #315404
Yes I setup as you wrote, see here nimb.ws/d5eaNU , but still in some categories products are Title A-Z
5 years 1 month ago #315413
Your screenshot is for the menu item "BRILLBIRD kategorije".
However, on the page www.brillbird.com.hr/shop/kategorija/59-gradivni-gelovi it's your menu item "shop" which is used. So you need to check the settings of that "shop" menu item for the ordering of that page.
