Help with product listing...
4 years 11 months ago #316681
-- HikaShop version -- : HikaShop Business: 4.2.3
-- Joomla version -- : 3.9.16
-- PHP version -- : 7.1
-- Browser(s) name and version -- : Firefox 74
What i would like to know is how can i change the table view for product listing...
What i would like to show is below.
Image then Title and Price nder the title i would like to show a description or a short description of the item they are looking at...
Can you help me...
4 years 11 months ago #316685
First, in order to have what you request, you have to go in your required Item Menu.
1. Go to Menus dropdown => Main Menu
2. Select your required Item Menu, click on Name to edit
3. Go to Products options tab
4. Reproduce this configuration from my screenshot :
Click on the image to see more details
For have the product description on your products listing, this will require a custom via an override view.
Have a look on this other thread to see how to proceed.
Hope this will fit your needs.
Last edit: 4 years 11 months ago by Philip.
4 years 11 months ago #316729
Hi Philip
Thanks for your help - below is a photo of what i would like to achive ...
  • Thank you received: 13502
4 years 11 months ago #316735
If you're using the "table" layout in your menu item settings, then you should already have something quite close to that, with only the "product description here" missing.
And you could easily add it, by adding the code:
<br/><?php echo $this->row->product_description; ?>
after the code:
<?php echo $this->row->product_name; ?>
in the file product / listing_table.php via the menu Display>Views
4 years 11 months ago #316777
Hi Nicolas
Thanks for your help :)
