Product listing miltiple images per product
4 years 8 months ago #321385
-- HikaShop version -- : 4.3.0 Business
-- Joomla version -- : 3.9.8
-- PHP version -- : 7.2.6
The "Link to the product page" is disabled as a product has only title, price and images in our webshop . Product details view does not add much value in our case and I want to keep the shop compact.
Is it possible to show multiple images for one product in product listing?
- It might be good for me if the small thumbnails are shown or
- a custom view with a slider automaticaly changing pictures
Is there an official support for such feature?
BR,
Daniel
Last edit: 4 years 8 months ago by bendegoose.
  • Thank you received: 13502
4 years 8 months ago #321412
There is no option to do that.
You'll have to edit the file product / listing_img_title.php via the menu Display>Views and add custom coding to load the images data from the hikashop_file table with a MySQL query and then display a carousel of the images (you can inspire yourself of the product / carousel.php view file to generate a carousel with the owl carousel library included in HikaShop).
Now maybe you could contact www.magictoolbox.com/hikashop/ and check with them if they could add that capability to their extension for HikaShop.
It could be a nice option for them to be able to do that since we don't plan on adding that capability by default in HikaShop.
The following user(s) said Thank You: bendegoose
4 years 8 months ago #321459
Thanks for the reply and the hints!
