Problems with form in product description
  • Thank you received: 18
4 years 4 months ago #325097
I need to include form (acymailing module) in product description. But there is a problem that product description is part of form, so form in form is not working (nested form).
I cant assign module to product page, as there is no menu item for product.
Any other idea how to include form in product description?
  • Thank you received: 13498
4 years 4 months ago #325107
Several solutions:
- edit the files show.php and show_default.php of the view "product" via the menu Display>Views to move the description outside of the product page form. If you know PHP/HTML it shouldn't be a problem.
- install advanced modules manager pro on your website. It will add extra options to your modules, including options to display the module only for the product page, and / or only for some products so you'll be able to use a standard position of your template.
- install the extension modules anywhere and edit the file show.php to add the tag for that module outside of the form of the product page.
4 years 4 months ago #325127
I will use first solution. Is there any other problems that may expect by move description outside form? Insert add to cart link, microdata,.. etc?
As I see, I must move description part to show.php?
Last edit: 4 years 4 months ago by mojweb.
4 years 4 months ago #325138
Yes, you need to move the description part from show_default.php to show.php
If you do the change properly, it shouldn't impact microdata or anything else.
