Custom product layout is not applied to product variants
5 years 1 month ago #328843
-- url of the page with the problem -- : www.abibannerdrucken.de/
-- Joomla version -- : 3.9.24
-- PHP version -- : 7.4
-- Browser(s) name and version -- : Google Chrome 88.0.4324.104
Dear Hika-Shop-Team,
first of all: Thank you for your work and the great software you are developing in such a great way! Its working so fantastic, except one thing: I have created a custom product page layout called show_qm (mainly a copy of show_default but refers to a different listing_price-view, where I have inserted another name for the PER_UNIT-translation (now its PER_QM)). This view works fine on all main-products. But if I change the product to one of its child from the options menue, the view is not applied anymore (so in my case the PER_QM-translator changes back to PER_UNIT). I also have tried to insert the product-layout-name directly in the database.
Inside the DB-table hikashop_product there is a column named product_layout. But it seems like only the main-products are using this table to get their product-layout-information, because if i enter show_qm in a variant product there, nothing changes.
So my question is, where can I find the PHP-part that loads the Variants from database? I quess I have to add / change a few lines of code to get Hika-Shop read the database-column "product layout" when loading the product variants. Or is there any other way?
Thank you very much,
best regards
Niclas
  • Thank you received: 13940
5 years 1 month ago #328861
The listing_price.php view file is also called from the show.php view file for the display of the prices of the variants.
So if you only change the call to listing_price.php in the show_default.php view file, it will only apply to products without variants.
So in your case, I would rather recommend to follow our FAQ on this :
www.hikashop.com/support/documentation/106-faq.html
( you need to read the answer to the question "I sell packed products, how can I change "each" text in the product page ?" )
That way, you can achieve what you want by create a custom field of the table "product" and only customizing the "listing_price.php view file, which will be taken into account by both the show_default.php and the show.php view files.
