URL for related products
  • Thank you received: 24
3 years 3 months ago #337429
-- HikaShop version -- : 4.4.4
-- Joomla version -- : 3.10.3
-- PHP version -- : 7.4
Here passtheport.thr.nu/shop/white-port/20-ar...nardo-20-years-white I'm using related products, but the URL of if goes to passtheport.thr.nu/shop/s-leonardo-10-years-white , but it should go to: passtheport.thr.nu/shop/white-port/10-ar...nardo-10-years-white
It works on other pages: passtheport.thr.nu/shop/white-port/10-ar...nardo-10-years-white
Can I fix this in anyway?
Thomas
  • Thank you received: 13496
3 years 3 months ago #337439
You want to enter the URL you want in the "canonical URL" setting of the product. Then set the "force canonical URL on listings" setting to "use when specified" and it will use that URL instead of generating it dynamically.
3 years 3 months ago #337463
Thank you so much!
