Why quantity appear not same for some product?
  • Thank you received: 11
1 year 4 months ago #354486
-- Joomla version -- : 3.10.12
-- PHP version -- : 7.4.33
As image that been attach , the quantity field at product details page not standardize same.
Some is as first image but some is same as second image.
Do anyone know the reason?
  • Thank you received: 13400
1 year 4 months ago #354492
In each product you have a "quantity input" setting where you can define how the quantity input should look like. And so, it's possible to have a dropdown for some products, an input field for others, nothing for some others, etc. So you want to check this setting in your different products.
The following user(s) said Thank You: ler@singmuiheng.com
