Pagination and / or infinite scroll problem
2 years 11 months ago #355939
-- HikaShop version -- : 5.0.0
-- Joomla version -- : 3.10.12
-- PHP version -- : 7.3.3
In my installation of Hikashop I sort the products by product_quantity in descending order so that the available items are shown first.
Many products have the same quantity (0 or 1).
In one category I have 29 products.
I fetch the products 25 at a time.
When the infinite scroll is triggered, after the 25th item, I get the same the last 4 items of the first batch of 25 items.
The problem is the same even when I turn the infinite scroll off.
After much testing, debugging and digging I think I found the root cause: in MySQL ordering by a non unique field and then applying a LIMIT with an OFFSET returns inconsistent results.
The solution is to (also) order by a unique field.
I made a tiny modification to components/com_hikashop/views/product/view.html.php, at line 749:
$order = ' ORDER BY '.implode(', ', $order);
$order = ' ORDER BY '.implode(', ', $order); $order .= ', b.product_id';
The problem is now fixed.
(I'm not sure if the fix will cause problem with the RAND() sorting, thou)
Last edit: 2 years 11 months ago by forghy. Reason: formatting
2 years 11 months ago #355954
Thanks for the feedback.
I do think that this change will be problematic with RAND()
I think it will be better to add :
$order[] = 'b.product_id ASC';
after the line:
$order[] = $pageInfo->filter->order->value.' '.$pageInfo->filter->order->dir;
in the same file. That way, it won't affect the query when RAND() is being used.
Can you confirm that it also helps on your end ?
The following user(s) said Thank You: forghy
2 years 11 months ago #355955
Perfect!
I confirm that it solves the problem just as well.
Thanks so much.
May I ask you if you think this modification will be part of a future release?
2 years 11 months ago #355956
Yes, I'm planning on adding this to the next version of HikaShop. Thanks for your feedback.
Time to create page: 0.037 seconds
