- Thank you received: 28
CSS for top right corner alerts
2 years 6 months ago #360712
by yerg55
CSS for top right corner alerts was created by yerg55
How to edit the alerts such as ... item has been added to the cart ... so that it's more readable
Also how to adjust the time delay on that alert as well.
2 years 6 months ago #360714
Replied by nicolas on topic CSS for top right corner alerts
The delay can be modified in the settings of the HikaShop cart notification plugin via the Joomla plugins manager.
The text in these alerts can be changed with translation overrides:
The style of the alert boxes can be changed with CSS code.
Here is a tutorial on how to add custom CSS to HikaShop:
2 years 6 months ago - 2 years 6 months ago #360772
by yerg55
Replied by yerg55 on topic CSS for top right corner alerts
Time delay working now - thanks
Language translation works fine as is
Alert boxes has been challenging not only there but others.
Editing the Front-end CSS File and Styles for the front-end custom css doesn't achieve anything
Changing colour yes, anything such as font family or font size is crossed out / ignored
Chased down other CSS that refers to J! alerts and the two files that are referenced
/media/joomla-custom-elements/joomla-alert.css
/media/joomla-custom-elements/joomla-alert-min.css
Regardless of editing nothing changes.
Digging time ?
Thanks again
Digging time ?
Thanks again
Last edit: 2 years 6 months ago by yerg55.
2 years 6 months ago #360774
You need to add CSS, not change it.
As the tutorial link I gave explains, you can use the inspector tool of your browser on the elements you want to style in order to find the CSS code already applying to the elements and write and test the CSS code you want to use to override the default CSS.
Here is an example of what someone else added to change the colors of these alert popups:
www.hikashop.com/support/forum/orders-ma...st-popup.html#279849
2 years 6 months ago - 2 years 6 months ago #360820
by yerg55
Absolutely understand why that's necessary.
Figured I'd test that way as well as these below
This is what I've added to force something dramatic to ensure I can see changes.
Colours work great.
Font Family and size are totally ignored / struck out.
That's all for the negative alerts
Now for the add to cart alert
This style is referenced at ..... /media/com_hikashop/css/notify-metro.css?v=504
I changed the font family to Arial.. No change
Out of desperation what I've done is added ALL the changes I am seeking into the system config.css, the media/com_hikashop/css, and all other CSS files.
NO cache enabled on the site as well just to be sure
Yup I'm desperate. :S
- I've added everything I wish to change in the custom.css in Hikashop
- I've added everything I wish to change in the custom.css in Template as well.
.notifyjs-metro-base.notifyjs-metro-warning {
color: #CD0000 !important;
background-color: #fafafa;
border: 1px solid #CD0000;
font-family: "Arial";
font-size: 20px;
Colours work great.
.notifyjs-metro-base .text-wrapper, .notifyjs-metro-lite-base .text-wrapper {
text-align: left;
font-family: 'Segoe UI';
Last edit: 2 years 6 months ago by yerg55. Reason: clarity
2 years 6 months ago #360822
Well, it's hard to say anything precise without being able to study the situation directly with my browser's inspector tool.
Could you provide the URL of the pages and instructions to reproduce the different alert boxes and explain how you're trying to change them so that we can study the situation ? With all that, we should be able to tell you what you're missing.
2 years 6 months ago #360830
by yerg55
Same product 2 options
newfreedombakery.com.au/2023/pastries/pr...astie-meat-vegetable
Add two and yup it's ok
Add 4 and not so good
I've been a dab hand at styling since Mambo OS and Virtuemart :blink:
This one has me absolutely stumped
Thanks Nicholas
Thanks Nicholas
2 years 6 months ago - 2 years 6 months ago #360832
by Philip
Replied by Philip on topic CSS for top right corner alerts
In order to increase your css command priority the "!important" is a solution, BUT if there are another command that use an "!important" then the other way to override css command is to have a better selector.
Example :
=> From least priority to most priority
.html_class
.html_class div (or p, a, span etc...)
#container_id (or .container class) .html_class div
In your case we notice that you are targeting the container of your texts, so try adding the tag (div, span) and/or the class of your text element.
AND if that still doesn't work, add a class containing your entire notify popup.
Example :
.html_class
Last edit: 2 years 6 months ago by Philip.
The following user(s) said Thank You: yerg55
2 years 6 months ago - 2 years 6 months ago #360850
by yerg55
Understand your logic Nicholas and thanks for your patients
ALL the edits I made were simply to change font-family: to Arial and font-size to 20px in existing CSS files that were referenced in the live outcome.
Situation / Resolution
I'm using Gantry framework / theme
I ended up putting ALL the css changes into the template/custom/scss/custom.scss file and recompiling the css.
Finally resolved
:woohoo:
Finally resolved
:woohoo:
Last edit: 2 years 6 months ago by yerg55. Reason: Resolution found
