Problem with category images
2 years 1 month ago #362199
-- HikaShop version -- : 5.10
-- Joomla version -- : 4.4.6
-- PHP version -- : 8.3
Hi, I have a problem with centering the images for categories. For products, there are no issues; the images are centered by default. However, for categories, they are not. I have tried this on at least three Joomla installations with the latest release, including one without any installed templates, only Cassiopea, but the categories are always off-center. How can I resolve this? Thanks.
2 years 1 month ago #362202
I think that it is probably because the "force size" setting of the HikaShop configuration is turned off. This, or there is some CSS from your template messing with the display there.
We would need a link to this page in order to look at its CSS in order to tell you exactly what to do
2 years 1 month ago #362237
yes, try with this credentials
Please delete credentials on this post after use, thanks in advance
Last edit: 2 years 1 month ago by nicolas.
2 years 1 month ago #362239
Add this CSS and it will fix the problem:
img.hikashop_product_listing_image {
    margin: auto;
The following user(s) said Thank You: cesco1701
2 years 1 month ago #362313
super! problem solved :) many thanks
Time to create page: 0.233 seconds
