HikaShop and SP Page Builder Tabs problem
8 months 2 weeks ago #362706
-- HikaShop version -- : 5.1.0
-- Joomla version -- : 4.3.3
-- PHP version -- : 8.1
-- Browser(s) name and version -- : Opera GX/Google Chrome
Dear HikaShop,
I'm trying to use the latest SP Page Builder's Tabs (which are present since the version 3 afaik) and found out that if I place HikaShop content modules in each tab, they wont switch between the tabs. I tested with other modules if it's affected with other type of modules like Smart Slider 3, etc., but they worked fine with them so it is only happening when I place HikaShop modules only.
Also, it seems to work fine from the SPPB's frontend edition page with hikashop modules as well.
Do you have a solution for this?
I've included the problematic web page privately so you can check the problem by switching the SPPB tabs there between "Tab with HikaShop module", an other tab including a SPPB heading addon named "Fresh text" and another module next to it with a different HikaShop module (also a content module with different ID).
It also puts a big blank area below if there are more than one Hika module included and it's breaking the side menu that should be next to the items.
Thank you for your help in advance,
FRIK
  • Thank you received: 13545
8 months 2 weeks ago #362709
I think this is a customization issue. It seems that there is some closing div missing in the products listing. Because of this, it messes the structure of the tabs system as well as the side menu.
Rename temporarily the folder templates/YOUR_TEMPLATE/html/com_hikashop/product/ to something else via FTP in order to deactivate all the customizations of the products listing.
Then, clear your website cache if any and try again. It should hopefully work, indicating that the problem comes from one of the view override files in that folder. You can then rename the files in that folder one by one in order to find out which one is creating the problem.
