Display message for products that do not have characteristics
  • Thank you received: 6
1 month 1 week ago #365800
-- HikaShop version -- : 5.1.3
-- Joomla version -- : 5.2.4
-- PHP version -- : 8.1
why hikashop Display "The add to cart button will appear once you select the values above" message for products that do not have characteristics?
I looked at the codes in this section. It says if there is a characteristic or if the character is not a list type. I think you should replace or with and.
  • Thank you received: 13512
1 month 1 week ago #365802
It could be because of a side effect of a fix we made in the 5.1.3. We've added a patch for this since then so I would first recommend updating to the 5.1.4
