Add more than 15 products
6 days 16 hours ago #366452
-- HikaShop version -- : 5.1.5
-- Joomla version -- : 4.4.12
-- PHP version -- : 8.5
-- Browser(s) name and version -- : chromio
Good morning,
I have created a cart with a simplified view and a dropdown selection for the number of products. HikaShop has set the maximum selectable value in the dropdown to 15 pieces. How can I change and increase this value?
Thank you.
  • Thank you received: 13522
6 days 3 hours ago #366457
There is a hidden option for this. Go in your PHPMyAdmin, open the hikashop_config table and add a new entry with the namekey "quantity_select_max_default_value", with the value being the quantity you want as the maximum option of the quantity dropdowns.
6 days 20 minutes ago #366460
Thanks, solved!
