UPS Price difference for less than 1 LB
8 years 4 months ago #257726
-- Joomla version -- : 3.6.0
-- PHP version -- : 5.6.19
I am using UPS plugin and I am having an issue with the order having less than 1 LB size. It gives prices which are applicable for more than 1 LB. Ups Give 50CAD whereas plugin returns 63.16 for UPS Saver.
XML Snippet -
<Package>
  <PackagingType> <Code>02</Code> </PackagingType>
  <Description>Shop</Description>
  <Dimensions>
    <UnitOfMeasurement> <Code>IN</Code> </UnitOfMeasurement>
    <Length>0</Length>
    <Width>0</Width>
    <Height>0</Height>
  </Dimensions>
  <PackageWeight>
    <UnitOfMeasurement> <Code>LBS</Code> </UnitOfMeasurement>
    <Weight>0.36</Weight>
  </PackageWeight>
</Package>
Result -
<?xml version="1.0"?>
<RatingServiceSelectionResponse>
  <Response>
    <TransactionReference>
      <CustomerContext>Rating and Service</CustomerContext>
      <XpciVersion>1.0</XpciVersion>
    </TransactionReference>
    <ResponseStatusCode>1</ResponseStatusCode>
    <ResponseStatusDescription>Success</ResponseStatusDescription>
  </Response>
  <RatedShipment>
    <Service><Code>08</Code></Service>
    <RatedShipmentWarning>Your invoice may vary from the displayed reference rates</RatedShipmentWarning>
    <BillingWeight>
      <UnitOfMeasurement><Code>LBS</Code></UnitOfMeasurement>
      <Weight>1.0</Weight>
    </BillingWeight>
    <TransportationCharges>
      <CurrencyCode>CAD</CurrencyCode>
      <MonetaryValue>174.14</MonetaryValue>
    </TransportationCharges>
    <ServiceOptionsCharges>
      <MonetaryValue>0.00</MonetaryValue>
    </ServiceOptionsCharges>
    <TotalCharges>
    </TotalCharges>
    <GuaranteedDaysToDelivery/>
    <ScheduledDeliveryTime/>
    <RatedPackage>
        <CurrencyCode/>
        <MonetaryValue/>
        <CurrencyCode/>
        <MonetaryValue/>
      <TotalCharges>
        <CurrencyCode/>
        <MonetaryValue/>
      </TotalCharges>
      <Weight>0.4</Weight>
      <BillingWeight>
        <UnitOfMeasurement><Code/></UnitOfMeasurement>
        <Weight/>
      </BillingWeight>
    </RatedPackage>
    <NegotiatedRates>
      <NetSummaryCharges>
        <GrandTotal>
          <MonetaryValue>59.21</MonetaryValue>
        </GrandTotal>
      </NetSummaryCharges>
    </NegotiatedRates>
  </RatedShipment>
  <RatedShipment>
    <Service><Code>65</Code></Service>
    <BillingWeight>
    </BillingWeight>
      <MonetaryValue>185.75</MonetaryValue>
    <TotalCharges>
    </TotalCharges>
    <GuaranteedDaysToDelivery>1</GuaranteedDaysToDelivery>
    <RatedPackage>
        <CurrencyCode/>
        <MonetaryValue/>
        <CurrencyCode/>
        <MonetaryValue/>
      <TotalCharges>
        <CurrencyCode/>
        <MonetaryValue/>
      </TotalCharges>
      <BillingWeight>
        <Weight/>
      </BillingWeight>
    </RatedPackage>
    <NegotiatedRates>
      <NetSummaryCharges>
        <GrandTotal>
          <MonetaryValue>63.16</MonetaryValue>
        </GrandTotal>
    </NegotiatedRates>
  </RatedShipment>
</RatingServiceSelectionResponse>
Could you please tell me if there is anything I can do to get the same price?
Thank you,
8 years 4 months ago #257768
Hello !
UPS services rates are calculated and returned by the UPS platform, so the only way to make the price change will be to :
- Directly use the "Price" option of your shipping method configuration page
- Adapt the informations sent to the UPS platform by editing the code of the UPS plugin.
