Total of your order is too low for all possible shipping methods
  • Hikashop Essential
7 years 3 months ago #285828
-- Joomla version -- : 3.8.3
-- PHP version -- : 7.0.22
-- Browser(s) name and version -- : Firefox 57.0.4 64-bit
-- Error-message(debug-mod must be tuned on) -- : Notice: Trying to get property of non-object in /home/localm9/public_html/uhansworkwear.com/plugins/hikashopshipping/ups/ups.php on line 794
Warning: Invalid argument supplied for foreach() in /home/localm9/public_html/uhansworkwear.com/plugins/hikashopshipping/ups/ups.php on line 794
This worked for a couple years now all of a sudden no products can be bought that are less than $99. Anything over $99 uses a manual shipping method and is free shipping and customers can buy products. Anything less than $99 uses the UPS shipping method and all of a sudden doesn't work, people aren't allowed to buy products. Please help. I've tried for hours to figure out....thanks.
  • Thank you received: 13533
7 years 3 months ago #285830
These messages indicates that the UPS plugin is not able to retrieve the rates from the UPS server.
So either something change in the settings of your UPS shipping method (like you changed a credential), or their counterpart on the UPS account changed, or your server is not able to access the UPS server anymore due to a firewall change at your hosting or something like that.
So please first check these.
7 years 3 months ago #285865
Okay Nicolas. I called my hosting co and they said nothing has changed. Everything is the same. I called UPS and they said the same thing. Before I even sent this request in I found out that the UPS password had changed (so I thought I had fixed the problem) and I switched it but it still gives me the "The total of your order is too low for all the possible shipping methods". I created a new UPS shipping method with a new UPS access key and tested that. It returned the same error code. I took off the $99 restriction. Same result.
Sorry to bother you with this but I really don't know what else to do. Thanks for your help....
  • Thank you received: 4035
7 years 3 months ago #285871
The message "The total of your order is too low for all the possible shipping methods" means that you have an available shipping method in HikaShop which have a weight restriction and that your current cart is below that weight limitation.
7 years 3 months ago #285967
I don't have any weight restrictions on any shipping methods. Did you read the error messages on my original post? Thanks.
7 years 3 months ago #285968
Also, there was a change in my clients UPS password. I changed the password to the new correct password and I still get the error message. Would there be an issue where a changed password is stored somewhere so when I change the old password, that it still won't work?
7 years 3 months ago #285999
Can you send us screenshots in which we can correctly check :
- Your shipping method configuration page
- How you configured your product used when testing your shipping plugin
- The shipping address used during your test.
So that we can reproduce and test it on our end ?
Thank you.
7 years 3 months ago #286034
Okay. Here's the screenshots you requested.
Test address: 4270 Laura Ln, White Lake, MI 48383
Last edit: 7 years 3 months ago by jdean. Reason: Didn't want to show info in an open forum
7 years 3 months ago #286061
It's actually working fine on our end, can you give us a temporary access to you website so that we can directly test and debug it on your end ?
You can send it using our contact form by also adding a like to that thread in you message :
Thank you.
7 years 3 months ago #286112
Okay, I sent an email with your contact form. Thanks again.
7 years 3 months ago #286141
I'm getting the following error message when I try to access your website administrator panel :
Error 403 - Forbidden
You don't have permission to access the requested resource. Please contact the web site owner for further assistance.
Can you also send us a link that we can use to access it ?
Thank you.
7 years 3 months ago #286185
Okay, I took care of the problem. Please access back end as usual. Thanks.
7 years 2 months ago #286208
This time I'm having this error message while trying to access to the back-end section of your website :
Not Found
The requested URL /administrator/ was not found on this server.
7 years 2 months ago #286248
Sorry about that. I changed the name of the wrong file. It should work now. Please try again. Thanks...
7 years 2 months ago #286382
The following error message was actually coming from the manual shipping method named "Free Shipping" with a "Minimum Price" set to $99.01 :
Also, your issue seems to be coming from your server, as the response from the UPS platform after sending our request is :
Access denied
You don't have permission to access "Rate" on this server.
You should probably contact your Hosting company about it.
7 years 2 months ago #286741
Okay. I have a response back from UPS. They say that one possible issue may be that the plugin developer hasn't made the UPS plugin support TLS 1.2. Can you confirm that the UPS plugin does support and serve up TLS 1.2. If not the plugin will no longer work as per UPS. Thanks.
7 years 2 months ago #286786
I just tested it today on a local website (using PHP7) and it's working ; the plugin do have the HTTPS support and no action should be required.
So it means that the issue comes from your hosting ; which is not related to HikaShop or our support.
You have to see with your web hosting your SSL version and support of TLS1.2
Best regards,
Mohamed Thelji.
7 years 1 month ago #289566
I just got off the phone with UPS and they said the plugin was sending the request to the wrong address. The correct address should be onlinetools.ups.com/ups.app/xml/Rate
FYI
7 years 1 month ago #289625
We just changed the address used by the UPS shipping plugin and it's still working fine.
You'll be able to test it after downloading the last Hikashop version through our website and install it.
Thank you for your feedback !
1 year 4 months ago #357629
Hello Team,
I am also having the same problem.
please check the screenshot: prnt.sc/75ctdxXj4_pm
The website URL is: compostwerks.com/
Please check configuration page: prnt.sc/al_NLT7XHw3l
so please help me
