problem with TAXES
11 years 6 months ago #194064
-- Joomla version -- : 3.4
Hi (I removed the old text since I found the solution by myself)
Just a question
I want to add a text to tax exempt customers (they are included in a "0%" tax rule).
Is there a way to add this sentence to invoices?
Last edit: 11 years 6 months ago by nbstudio.
11 years 6 months ago #194137
I solved it by myself. I was too tired to notice.
Just a question
I want to add a text to tax exempt customers.
11 years 6 months ago #194166
You can edit invoices via the menu Display>Views by editing the file "invoice" of the view "order".
You could do something like that:
<?php if($taxes==0.0){
echo "you are tax exempt";
You can add that code at the end for example.
11 years 6 months ago #194339
hi nicolas.
suppose I have 2 different exemptions (one for Europe, one for outside EU)
the two are actually correctly applied to orders.
in these two tax rules, I've added the legal text to the field TAX NOTE,
is there a way to print it in the invoice according to the tax rule applied?
11 years 6 months ago #194361
I don't see any easy way to do that as the tax amount in the order is not linked to the tax rule/tax note.
So you can't know which tax note to display. It would require hacking in the code of HikaShop to get that information when the tax rules are calculated and then store that information in the order when the order is created so that you can then display it in the invoice.
A simpler solution will be to have such code:
if(in_array($this->element->shipping_address->address_country,array('France','Germany', ...etc... ))){
echo "you are tax exempt in europe";
}else{
echo "you are tax exempt outside europe";
11 years 6 months ago #194821
thanks. I made the modifications and after some hours of struggle, I succeeded.
Time to create page: 0.360 seconds
