Problem exporting & importing all products.
12 years 2 months ago #65055
My 1.5.8 website is nearly finished, but is probably a bit of a mess as it was a learning curve.
So I am attempting to create a fresh clean website with 1.6.0 making the various modifications to my template as I did before.
In order to transfer all my products from 1.5.8 site to the 1.6.0. site I exported all the 1.5.8 products to a .csv file.
Then without any modification, I tried to import them into my 1.6.0 site, which I expected to be error free.
However I get an error saying a column heading of 'print:' is invalid, and that of the 64 products found, 16 had invalid codes and 48 already existed?
I don't understand this, as there are no products in the 1.6.0 site yet.
Many thanks
12 years 2 months ago #65064
Apologies, the products do seem to have imported OK, despite the error messages.
  • Thank you received: 13362
12 years 2 months ago #65173
The error message tell you that you have a "Print:" which is not known by your new website. So that particular data of your products was not imported for the products.
I suppose that it must be a custom field or something like that ?
