How to order products newest on top oldest on bot
11 years 10 months ago #93542
Hello
I have hika 1.6 Business edition :laugh:
Can't order the products like this :
New products on top of the display.
Old prodoct on bottom of the display.
I' m thinking and order buy product_id would be a good choice, but I need to be order like :
-prodoct with bigest id on top
-product with smalles id on bottom.
And by the way hikashop 2.1.0 works on joomla 2.5 ?
Florin M.
11 years 10 months ago #93563
I think that you'll just have to use the "order" option of your product listing, and set it to product_created.
Hope this will help you.
11 years 10 months ago #93582
I try that but no success.
Joomla has cache support activated. I had cleared and purged the cache.
Still the same thing.
Does anybody know how de display of product works ?
What I hate about hika is that are no comments on the code like what does that function, you have to guess.
Florin M
Last edit: 11 years 10 months ago by FlorinM.
11 years 10 months ago #93618
Then you should maybe change the value of your Ordering direction option through your product listing's configuration screen.
11 years 10 months ago #93683
That is it.
Thanks,
You opened my eyes.
Florin M
11 years 9 months ago #95503
I have the same problem, but regardless of what I try, playing with "Ordering direction" and "Ordering field", nothing in the order changes. Probably I miss something....
11 years 9 months ago #95577
Are you sure that you are editing the correct menu ?
Your parameters seems to be correct.
11 years 9 months ago #95623
Yes, it worked, for some reason the change was not reflected immediately...
