Add package / box weight to total products weight
11 years 8 months ago #102861
Please where can i set a custom package / shipping box weight,
which will be added to the total weight of products,
and after that, it will be calculated the shipping price on checkout ?
I'm using manual shipping plugin.
Thank you very much
  • Thank you received: 26
11 years 8 months ago #102879
So you want different weights for different parts of the product? (one for the item one for the shipping weight?)
I'm not an expert at this, if i post on your thread i'm doing so with the best of my knowledge and just trying to help :)
The following user(s) said Thank You: Hátle
11 years 8 months ago #102891
Nope, i just want to specify a weight of the shipping box to the manual shipping plugin.
The shipping price will be calculated from the "weight of the products" + "shipping box weight" then.
Last edit: 11 years 8 months ago by Hátle.
11 years 8 months ago #102892
on the product itself you see the weight, you fill that field in then it would work.
  • Thank you received: 13409
11 years 8 months ago #102917
There is no need for that Hátle.
For example, suppose that you have a product weight of 2kg and a shipping box weight of 1kg, and suppose that you have one shipping method with weight restrictions of min 1kg and max 5kg.
Then, instead of have a manual shipping method with these min and max weight, just remove the shipping box weight from the weight restrictions of the shipping method, so you would get a min weight of 0 and a max weight of 4kg in your manual shipping method.
11 years 8 months ago #102995
You got the point :-)
