sub products or child products
10 years 6 months ago #161014
is it possible to have child products or addons like this,
www.bigsavingszone.com/productdetails.ph...egory=&categoryId=12
so that one main product is added to cart and someone also can add multiple sub products for the same in cart..
thanks,
SS
-- Joomla version -- : x.x
-- PHP version -- : x.x.x
  • Thank you received: 13406
10 years 6 months ago #161042
You can have variants of products with the characteristic feature:
www.hikashop.com/support/support/documen...html#characteristics
And you can change the "characteristic display method" option of the configuration to "list" in order to have your variants display in a similar manner on the product page.
You can have an add to cart button for each variant but there is no option for now to have a global add to cart button on the listing of variants.
10 years 6 months ago #161794
So what is my option to achieve thing like www.bigsavingszone.com ?
thanks,
SS
10 years 6 months ago #161800
As Nicolas said, you will have to use the variants and display them in list.
To have a very similar display, it will require too some view overrides:
hikashop.com/support/support/documentati...ize-the-display.html
