Products order for inserted products in articles (simple solution provided)
5 years 3 weeks ago #335586 by dyvel
Free Akeeba subscriptions
Free Shipstation (legacy)
€ 50,00 HikaSubscription Update, support and services Choose options
Free Product order history
€ 90,00 HikaSubscription Update, support and services: Two years Add to cart
To order by the order of ids, I modified the file: plugins/system/hikashopproductinsert/hikashopproductinsert.php in line 279: Change: To this: Now the order is respected. I hope you will consider adding this to the plugin for the next update? Have a nice day." class="hasTooltip topictitle">Products order for inserted products in articles (simple solution provided) was created by dyvel
-- Joomla version -- : 3.10.1
-- PHP version -- : 7.4
Often, when I use the hikashopproductinsert plugin to insert products in articles, I need the products to be in a specific order - as in the order I add the ids, but as of now, the order is not respected in the query (it's missing an order by).
Just for reference, I insert products like this:
in line 279:
Change:
$product_query = 'SELECT * FROM ' . hikashop_table('product') . ' WHERE product_id IN (' . implode(',', $ids) . ') AND product_access='.$db->quote('all').' AND product_published=1';
To this:
$product_query = 'SELECT * FROM ' . hikashop_table('product') . ' WHERE product_id IN (' . implode(',', $ids) . ') AND product_access='.$db->quote('all').' AND product_published=1 ORDER BY FIELD(product_id, ' . implode(',', $ids) . ')';
Have a nice day.
5 years 3 weeks ago #335608 by nicolas
Replied by nicolas on topic
Yes, we can add that modification.
Thanks for your feedback and contribution.
Time to create page: 0.188 seconds
