Problem with thumbnail in cart module and chechout
10 years 1 month ago #192649
Show diferent thumbnail in cart module and checkout. In administration all pictures are with 0 in position.
Code for the thumbnails:
<?php
	$image_options = array('default' => true,'forcesize'=>$this->config->get('image_force_size',true),'scale'=>$this->config->get('image_scale_mode','inside'));
	$img = $this->image->getThumbnail($row->images[0]->file_path, array('width' => $width, 'height' => $height), $image_options);
	if($img->success) {
		echo '<img title="'.$this->escape(@$row->images[0]->file_description).'" alt="'.$this->escape(@$row->images[0]->file_name).'" src="'.$img->url.'"/>';
Last edit: 10 years 1 month ago by Jerome.
  • Thank you received: 13545
10 years 1 month ago #192768
In your products, you should set the order values of your images with numbers instead of 0s. The lower number will be the one used on both listings. If you have several images with the same lower number, you might get a different image used as the queries loading the data of the images from the database need to be done differently.
