Vote and module Related Products - problem
  • Thank you received: 19
8 years 3 weeks ago #262162
Hi I found the following problem when you switch example the second page of comments on product - the module related products disappears. I also want to ask is it possible to make comments to be loaded without the need for reloading the page (like the new system in version 3)
Last edit: 8 years 3 weeks ago by neo191987.
  • Thank you received: 13490
8 years 3 weeks ago #262192
It seems you didn't provide a link to the page you're talking about. Could you provide that so that we could directly look at the problem and analyze it ?
If you want to change the way the system works to load comments in AJAX, it sure is possible but will require some heavy code change. You'll need to have a developer to work on that. Note that we spent almost 2 years on HikaShop 3.0.0's new checkout and new cart systems as we had to almost start from scratch. It might look similar to what was before, but that was done for backward compatibility. The system behind is totally different in order to accomodate the AJAX system (dynamic refresh) properly.
